RE: 6XAS mixing limitations
Hmmmm - good idea, Mike-
1-4 slaves the rudder to the ailerons, allowing coordinated turns, like you'd need for a Cub. For knife edge, you'd want the opposite - the rudder would be the master. I read the original post as specifically asking about having the rudder (4) as the master. Maybe I'm mistaken.
The elevator to flaperon mix is 2 - 6, there is also a 6 -2, and an airbrake. But if ilikeplanes is after a knife-edge type mix, none of those will do him any good, I don't think.
ilikeplanes, can you clarify a bit - which channel is the master?
thanks
