RE: 6XAS mixing limitations
Greetings,
Are you aware that ATV is set separately for left/up and right/down for each channel? This allows aileron differential, for example, by setting up at 100% and down at 80%. Or, more rudder on one side than the other.
You could use the PMIXes to couple rudder to channels one and six when you wanted. Rudder input would produce aileron "correction."
The 1-->4 (coordinated turns) mix is always "ON" once enabled.
Good luck and hope this helps.
