RCU Forums - View Single Post - IS-3 Conversion Kit Chassis/wheels
Old 01-20-2020 | 03:20 PM
Lotuswins
A short update, things are coming together:
JS2 shackles, front headlight from damaged JS2 upper hull.
JS2 exhaust outlets and barrel rest. Had to make piece behind vent sheet since provided piece was too fragile. Note rear and front flaps over tracks are slightly different width, which is consistant with close observation of actual tank.
I decided to make the turret top removable, makes it easy to work on....ledge where turret base rests was uneven so I put jacking screws which have small magnets pressed into base so it snaps into place. I can jack the turret to gain minimum distance between upper hull and bottom of turret shell.
