Sheated the wing center section.
Added filler blocks to the wing l.e. where there was a gap between them and the fuse .
Shaped the dowel block on top of the fuse.
Got plenty of putty work. I have been using Hobbico HobbyLite filler. First time Iv'e used it. Seems to work pretty good. I have used light spackling in the past. I would same the wight is like about the same. Sands as easy. Sticks about the same.
Ken
