RCU Forums - View Single Post - ELMOD 3ton Issue
Old 02-11-2020 | 11:23 AM
smittyrob's Avatar
smittyrob
Default ELMOD 3ton Issue
:EDIT:
Fixed the issue. The firmware update for the sound unit kept failing when using the ELMOD app and there were only 2 update files in the list. When I launched the older ELMOD configurator program I was able to load older firmware files. This was successful and seems to have fixed the issue, everything seems to work again.
Mods please delete this thread if you think it necessary.
I have an Elmod 3ton truck board for the Opel blitz I am having a problem with. I have been testing this board for about a week when the Elmod app stated it needed a firmware update.
I updated the center unit fine, but when I tried to update the sound unit I keep getting firmware update failed.
The board will no longer run and the status led shows issue communicating with sound unit.
The manual says in this case to contact Elmod support. I have reached out to Dominique at RCtank.de for help, but I thought I would ask here as well if anyone can help.
The manual does not show a way to factory reset either that I can see.
If anyone has any suggestions it would be greatly appreciated.
Rob
