Guys, I understand what you are saying and I will try those suggestions and I'm sure one if not both will work. Carlos, your's is how Jetcat sets theirs up and I think Mark's is for the newer versions of the JetCentral's. My real question is, where in the KT manual does it suggest any of these failsafe setups? In the teach ECU, it goes through the steps setting end points from 0 to 100 with low and high trims but that's it as far as I can see. The only place I see where it mentions failsafe is on page 28 to teach the ECU your radio and on page 64 for diagnostic messages where it mentions that when the ECU sees a failsafe, it brings the engine to idle for .5 seconds and will hold idle for another 1.5 seconds if it continues in failsafe and then shutdown. My main thing is that the manual is well written and seems to cover everything except how to setup the failsafe(unless I'm not seeing it) which is a fairly important step?
