Tried to run her up but she is not drawing fuel. Compression is good everything appears sorted. I think there must be a caster clog in the needle valve. this little needle appears pressed in It is certainly not threaded. Need to think this one through. With these tiny engines it is best for me to put them down and take some time rather than plowing ahead in the heat of the battle.
Thoughts/Ideas? I might try stripping the case again and heating it up to see if I can pull the needle valve out?
