RCU Forums - View Single Post - SABAvio Lizard EDF Jet Build Log
Thread
02-21-2020 | 01:03 PM
1
HeliDirect
Jul 2006
21
Boston, MA
With the new arrival of the SABAvio Lizard Jet this Winter, we at HeliDirect start working on the EDF version Lizard as we have time. Still a couple of month before weather will be good enough to fly. We will post here our building progress as we go.
Here are some info about the new Lizard EDF Jet:
Technical Specifications:
Wing Span: 1380mm (54.3")
Length: 1550mm (61")
Dry RTF Weight: 5.8Kg - 6.5Kg / 12.3 lbs. - 14.5 lbs. (Dependent Upon Equipment Used)
Fuel Tank Capacity: 2 Liters (0.52 Gallons)
EDF Requirements:
(1) 100mm - 120mm EDF
(1) 160A - 200A ESC
(1) 12S 5000mAh LiPo Battery
Turbine Requirements:
(1) 4.5Kg - 12Kg Turbine
(1) Turbine Conversion Kit
More info of the Lizard Jet can be found here:
https://www.helidirect.com/collectio...urbine-jet-kit
Reply
Like
HeliDirect
View Public Profile
Send a private message to HeliDirect
Find More Posts by HeliDirect
View iTrader Profile
