Originally Posted by
David Jackson
Chris,
Just for clarification, you are connecting your Airpower AB rings to the T-One light control module?
yep. Works great.
the AB portion on the T1 light controller puts out what ever voltage you put in. The rest of the outputs are regulated.
a turbine ecu pack 3cell LIFE is what I’m using. Lights don’t get hot and burn bright
use 95mm light rings from AirPower.
