Originally Posted by
David Jackson
Similar issue with my Kt-100 powered PC-21. My remedy was to leave the fuel shut off valve opened while the engine was hot, but make sure to close the fuel shut off valve before refueling.
Thanks for advice , You are correct right after stop turbine, should not close the valve first. I called Li Kai and he also told me same and after I tried ,, doing great now ,
