Hello there! I'm eric a software engineer who's been programming and creating apps for two years.
Hopefully i can help you with your question, i also faced the same issue. bought Husban x4501s but the motor which won't run and the drone won't start...
First, Make sure, the "Return To Home" switch is in the OFF position. But is should display a message on the screen to turn the "RTH" switch OFF.
