RE: How do I unregister
Well..I just logged in as you and noted that you removed your email and other information fine. The only ones you did not remove were your name and the address field because you probably deleted them and those are required fields. Had you entered "private" or any other text that would have stopped the error message that was telling you those fields are required. I entered the text "Private" in those fields for you so you can now move on to other sites where everything works better than it does at RCU. Best of luck to you.
