How do I unregister
Banned
ORIGINAL: flyr905
Been there, done that!!,........Like everything else on this "website", that doesn't work either.
what happens when you try to edit and remove your information?
Banned
Well..I just logged in as you and noted that you removed your email and other information fine. The only ones you did not remove were your name and the address field because you probably deleted them and those are required fields. Had you entered "private" or any other text that would have stopped the error message that was telling you those fields are required. I entered the text "Private" in those fields for you so you can now move on to other sites where everything works better than it does at RCU. Best of luck to you.
Banned
you must still be subscribed to certain threads. go to this url and unsubscribe to any that you have set to retrieve email on:
http://www.rcuniverse.com/forum/subscribe.asp
My Feedback: (16)
GA
Marc, my hat is off to you. You are a pretty amiazing guy. I don't have the customer patience to put up with that kind of stuff. If he feels that bad, he can just create a filter for RCU mail and send it to the trash. He will never hear from us again.
Again, great patience
