RCU Forums - View Single Post - landing bounce
Old 03-26-2020 | 12:37 PM
  #77
airsteve172
Assuming that all is well with the plane and it's properly rigged, it must be considered that different airplanes exhibit different flying characteristics and have different requirements for pilot skills. With that out of the way, the one thing that always remains the same about a landing (except maybe on an aircraft carrier) is the fact that you should NEVER try to MAKE the plane land! It does that all by itself when it runs out of airspeed necessary for lift. If the plane returns to the air after a bounce, it wasn't ready to land in the first place.
The process of landing is to hold the plane off the ground for as long as possible as it runs out of airspeed, then the thing lands itself! Think of it like a contest to see how long you can keep the plane off the ground (while near the ground of course) as it loses airspeed, but if you do everything to keep it from settling down, it will end up landing itself perfectly and even if it hits a bump, it will not have enough energy to get back into the air. Force it to land and you've got problems, no matter how good a pilot you are otherwise!!!
