What I have found when somone has issues with bouncing on landing is that they are running the CG too far forward. Another probable cause is poor landing gear location. I have a 1/3 scale Reed Falcon that that has the gear a bit too forward, unless I do a full stall landing as you describe it will bounce. The 1/4 scale version has the gear a bit further back and does not exhibit the same behavior.
