RCU Forums - View Single Post - Data Analyzer Jeti DS-24 Question/Problem
Old 04-04-2020 | 01:31 PM
HarryC
Originally Posted by ravill
So, I went back to the logging screens, and they are on “auto”.
Under the sensor logging/set up screen, I see a BUNCH of stuff being logged, but I also see that the MGPS is here twice.
Do I need to press “auto”?
I once had a sensor showing up twice, using "auto" did not properly clear it. What did work was unplugging all sensors, press "auto" so that it sees there is nothing and wipes the slate clean, then plug all sensors back in. It should see them without needing you to press auto but you can if you feel the need. After that you may find that anything that used telemetry has to be deleted and done again, e.g. displayed telemetry boxes may have their label but no data, telemetry alarms not work, and so on.
