Originally Posted by
Fast Pilot
I have Real Flight simulator upgraded from version 5 to version 7.5 with controller Interlink Plus.
Where can I find Twist 60 to import in my simulator?
Do any of you have an add-on with Twist 60 in it?
Thank you
You have to get it from the Swap pages.
https://www.knifeedge.com/forums/ind...st-60_av.6895/
Note that this is an "aircraft variant" (AV), meaning it is changed from another one almost like it (the Twist 40). So you have to download the original too, to get the AV to work. Link for the original is on the page noted above.
These are old planes, designed for G4. May or may not need some adjustments in the aircraft editor in RF, as there have been a number of changes to the way the physics work.
