RCU Forums - View Single Post - Byron F15c Project
Thread
Byron F15c Project
04-13-2020, 06:59 PM
183
Pull Up Now!
My Feedback: (
3
I finished reinforcing the elevators with a heavy rib, covered over with carbon fiber. Also installed a tool steel hardened pivot rod.
Used construction paper to piece together the profile for the landing gear support formers.
Took a pic of the paper former, imported it into Solidworks, scaled it, and designed the actual cad gear support parts.
3D printed the formers to do a final fit check before actually machining the formers.
Everything in place, gears work, fit is good with a few design changes.
View from underneath of the left main gear.
Put the plane on it's back legs and use the stance to design the nose gear supports. I want a tiny negative AOA as it sits on the ground. I will probably have to cut down the strut a little.
Reply
Like
Pull Up Now!
View Public Profile
Send a private message to Pull Up Now!
Find More Posts by Pull Up Now!
View iTrader Profile
