RCU Forums - View Single Post - Pull out of hover = Unlimited Vertical?
Old 11-07-2003 | 05:52 PM
EXCAP232
My Feedback: (12)
Default RE: Pull out of hover = Unlimited Vertical?
Pretty much.
The only thing that does make a difference is when you are performing maneuvers on an upline. If the wings falls off from the plane slowing down then the answer is no. Since this is the 3D forum pulling out of a hover and climbing could be considered unlimited vertical. If you are flying a sequence and the plane slows or drops a wing during 2 snaprolls on an upline then you have a problem (and a downgrade).
EXCAP232
ORIGINAL: GPSpacewalker
If my plane can pull out of a hover does that mean that it has unlimited vertical?
