RCU Forums - View Single Post - Problem with Ultracote wrinkling - help needed!
Old 05-07-2020 | 06:03 PM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
If your plane is an ARF, it may be covered in brand X covering and it will not shrink. Ultra Coat should just shrink with a little bit of heat from a heat gun. If it is Monokote, it shrinks as it cools and is famous for wrinkles due to weather changes. Just be careful with the heat as the seams will pull apart. Good Luck, Dave
