After a while most kit built and all arfs even when new need some covering care. Just look up Ultracote instructions or Monokote instructions and they will give you a heat range.
I would use a heat gun and keep the heat away from the seams personally.
If you use a iron be careful there is a chance you could lay a wrinkle over and that will never come out.
Kit built Ultra sport. Nice plane you have!
