RCU Forums - View Single Post - Current 2m pattern planes are really ugly
Old 05-11-2020 | 03:07 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
The increased side area helps knife edge flight which includes rolling elements combined with looping elements. The current masters sequence has a figure 8 with full rolls on the top of each loop. That side area really helps maintain the proper arc of the loop while rolling. The smallish looking wings keeps inertia low during rolling maneuvers that will contribute to more accurate point and snap rolls, also helps keep weight in check. The long fixed gear is needed for the larger props we run on electrics. The small wings just behind the canopy ( Canalizer ) of which some designs use dual Canalizers are used to smooth out the airflow ( propwash ) prior to it reaching the tail. This really cuts down on the effects of spiral slipstream and P factor. The result is increased rudder authority. Going with a biplane like I did does the same thing.
JoeVen (12-02-2021)
