Len I believe you have the same light controller we have just a newer version in a nice case. The one big thing I do see different though is the voltage input. The one we have will take a 3 cell LIFE battery that the engine runs on. Not sure if that one will.
I have helped a guy with a plugnplay trouble shoot his airsystem. I might be able to help you also. One thing you need to do is hook it all up to a receiver and radio. It will not work unless you do. This was the problem he was having. The factory tests the system before they ship it. The airsystem is pretty complicated on this bird but if you break it down system by system its not to bad. But like I said make sure you hook it up to a receiver and then try it.
