After making several tanks..............a nice trick is to install some brass tubing ...1/4 " or so.....on the (projected ) trouble corners or other spots on the mold . Then you can use air pressure to push on those corner areas. Sometimes it helps pop the part loose. A tiny piece of tape over the hole keeps the epoxy out.
