RCU Forums - View Single Post - Nose wheel steering setup
Old 06-12-2020 | 08:16 AM
JacoS
Default Nose wheel steering setup
Hi all,
First time that I am posting on here.
I need some help with E-Flite 60-120 size 105° retract steering arm setup.
When I retract the gear the aluminium slider (that is supposed to disconnect the steering when the gear is retracted) sort of binds momentarily on its rod which causes the nosewheel to deflect. I can hear the gear motor takes some strain during that time, but it is very brief and the slider then unbinds, slides rapidly to its new position and the nosewheel centres itself.
Is this normal or should the wheel be able to retract without deflecting? I cannot attach a photo yet as I have not made enough posts yet.
TIA
Jaco
