RCU Forums - View Single Post - Nose wheel steering setup
Old 06-12-2020 | 11:41 AM
JacoS
Originally Posted by scale only 4 me
Typically you'll raise or lower that steering push rod so the clevis pivot point is at the same level as the retract pivot point,,, if it's too high or too low you can get that momentary binding,,
good luck
Yeah, I have noticed that the position of the pushrod on the slide makes a difference. I can manually move it up or down with my hand, but it will only stay there until I make a steering imput or obviously vibrations will move it to where it wants to be.
I thought of giving the pushrod a slight bend, but since it can pivot on the servo side and steering arm side it just moves back to its original position.
I have tried searching for instructions on how it is supposed to be set up or if someone else has had the same problem, but it seems I am the only one that managed to mess it up somehow
