well looks like I will have to find some plastic tube with a 6mm internal diameter, its not worth the risking that happening,specially before I seal and paint it. then have to reopen !. anyway I've also got to look at another set of servos to run the doors as the servo`s I have mg945 (I think 10kg rated ) have slip issues, when closed if I press gently down on the doors I hear the servo gears spin back, does this mean i need more powerful servos 20kg or even 30kg, or is this going to happen with every servo as I`m using them straight out as a hinge
at least I will be able to upload some piccys on the next post
