Hello guys,
Following elevator Mechanism, I build up elevator on top of plywood structure. However, on half way I thought 4mm plywood is little week, so I reinforced plywoods with 2 pieces of 4mm Carbon rod and 75gram carbon cloth,
By finishing elevator, all up weight is 3300 grams, including all 7 servos and linkages. Withouts servos, fuselage and wing together is 2950 grams (6.5 lbs) , which is before primer and paint.
