RCU Forums - View Single Post - futaba 6 exa interface
Old 11-08-2003 | 02:34 PM
jh
Default RE: futaba 6 exa interface
But i belive you can by pass the problem xp has with the parrael post by useing ppjoy and there is another software that links into it i think the link all the stuff is on this site. |Plus i also belive it will allow you to use your joystick with other progs as well
http://www.geocities.com/deonvdw/PPJoy.htm
K can someone check it out to see if it works.
now the next question is the actual wiring of the inferface the reson i am trying to push this is i do not have the stuff to build and program a pic chip.
So which version is correct when wiring a lead for this transmitter.
A pin 2 )------------------| 680 Ohm |---------*--------------------( Pin 10
Right-angle socket / Parallel-
on transmitter /\ ZPD 4,7 Port on
/ \ PC
B pin3 )--------------------------------------*--------------------( Pin 18
or is it
Or
Or
[img][http://users.belgacom.net/TX2TX/tx2t...fms.gif/image]
Or
|Which one will work as you can see i am getting confused by all these different diagrams which is correct????
|So can some one double check me on this as see if this prog will make it possible to get the parrel post working with xp
