Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 futaba 6 exa interface >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 11-02-2003 | 09:49 PM
Default futaba 6 exa interface
hi, does anyone have an idea of how to wire the futaba 6 exa to the fms simulator?
thanks
juan[&:]
Old 11-05-2003 | 10:55 AM
jh
Default RE: futaba 6 exa interface
hi there i am haveing the same problem
Old 11-06-2003 | 05:21 PM
When you say wire do you mean which pins, or do you mean what interface to use?
For the pins
http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb7.htm
You need to use pins 2 & 3 for FMS
If you are using XP or windows 2000 then you need a pic based interface, usb or joystick interface otherwise any of the serial/LPT interfaces will work.
You may experience problems obtaining the plug for the 6exa, If have them in stock, but currently only ship in the UK.
[8D]
Old 11-06-2003 | 06:15 PM
jh
k pins 2 and 3 on the transmiter?
what about the 3rd wire
Old 11-06-2003 | 07:28 PM
You only need 2 wires for the interface, the ground and signal out. ie pins 2 & 3.
Old 11-07-2003 | 09:43 AM
i have win xp, using the printer port will work??, and there's any wiring for the games port?
many thanks
juan cruz
Old 11-07-2003 | 12:51 PM
Hi
The printer port will not work under XP.
You need a pic based unit, USB or games port unit. ( the games port I have seen to build yourself require you to program a pic). I will find the links and post later.
Old 11-07-2003 | 11:54 PM
ok thank, i'll wait[&:][8D]
Old 11-08-2003 | 07:22 AM
Hi
Eric has joystick port on his site, the link is
http://myweb.absa.co.za/eric.brouwer/interface.htm
Old 11-08-2003 | 02:34 PM
jh
But i belive you can by pass the problem xp has with the parrael post by useing ppjoy and there is another software that links into it i think the link all the stuff is on this site. |Plus i also belive it will allow you to use your joystick with other progs as well
http://www.geocities.com/deonvdw/PPJoy.htm
K can someone check it out to see if it works.
now the next question is the actual wiring of the inferface the reson i am trying to push this is i do not have the stuff to build and program a pic chip.
So which version is correct when wiring a lead for this transmitter.
A pin 2 )------------------| 680 Ohm |---------*--------------------( Pin 10
Right-angle socket / Parallel-
on transmitter /\ ZPD 4,7 Port on
/ \ PC
B pin3 )--------------------------------------*--------------------( Pin 18
or is it
Or
Or
[img][http://users.belgacom.net/TX2TX/tx2t...fms.gif/image]
Or
|Which one will work as you can see i am getting confused by all these different diagrams which is correct????
|So can some one double check me on this as see if this prog will make it possible to get the parrel post working with xp
Old 11-08-2003 | 02:47 PM
JH the ground is pin 2 and signal is pin 3.
Old 11-08-2003 | 03:48 PM
jh
k thanks i got that the pin lay out is
321
654
3 signal out 2 is ground k thats no problem.
|I managed to get the pc to detect the transmitter but could not get any porgrams like FMS to detect it []
Old 11-08-2003 | 05:17 PM
jh
K| thanks all i got it all working but the pin setting for the transmitter are the wrong way round.
and i used ppjoy and this program http://users.skynet.be/delvaux/
now i can use my transmitter in xp with any program now.
Old 11-08-2003 | 05:41 PM
Be careful I just played with it and it screwed up my printing refusing to allow it to print anything the only option was to remove it (or disable it using control panel). Not the best way for any device driver to work.
Old 11-10-2003 | 07:47 PM
Ogriv's Avatar
Would you mind summing up what works for the 6exa? Will this interface work will my realflight simulator?
Old 11-11-2003 | 01:57 PM
jh
The bottom line is it does work. I have been useing my 6exa on xp for about a week and i have no problems other than sometimes i get a bit of noise and the aeroplane kicks to the side for a second. BUT YES IT WORKS.
Infact it makes your tansmitter into a joystick so you can use it with any sim
I have tried it with FMS, microsoft flight simulator 2004, Orbiter space sim ( www.orbitersim.com ) and verious others
Old 11-12-2003 | 05:59 AM
Ogriv's Avatar
What do you mean, wrong way round?
Old 11-12-2003 | 12:44 PM
jh
I mean the pins in the back of the transimtter i was told that 2 was for the signal and 3 was the ground i found it to be the other way round
Old 12-08-2003 | 03:42 AM
ORIGINAL: cubanflyer
PPJoy by design prevents any other hardware from accessing a LPT port hardware with a joystick configured. This is the proper way to write drivers - i.e. allocate a resource before you use it. Unfortunately the Windows kernel does not "open" a joystick device - so PPJoy cannot allocate the LPT port only when an application is reading the joystick.
Regards,
Deon
Old 12-08-2003 | 06:13 AM
Hypter's Avatar
You could be in trouble... Futaba suggests that you REMOVE the TX Crystal in cases like this, since its a computer radio you could end up with RF damage since there is nothing receiving what is being transmitted. I dont know if the 6EXA has the same problems as the 6XAS (being used on your PC or as a buddy box) But I used my 6XAS with RealFlight and I got "noise and the plane kicked sideways" and I was using the supplied RealFlight TX adapter cord. At first I didnt think anything of it until I went flying, SAME thing happed with plane as it did on the Sim, banked hard left with no input, so I email Futaba about it, they suggested that I send it in to have it looked at -- it was replaced because of "RF Damage" as they put it. Since then I take the TX crystal out before using it with the Sim or as a BuddyBox.
