Originally Posted by
Dansy
Wayne, I also don’t see any advantage....since you still have only one Signal input.....and I agree if it’s intermittent then fix it....don’t rubber band it. On the KingTech the ECU is actually power by the RX, the ECU battery is only for the Starter, glow and the fuel pump....
why run 2 RX batteries ? If you dont trust your system fix it ! Dont rubber band it !
