Originally Posted by
aaronforth
why run 2 RX batteries ? If you dont trust your system fix it ! Dont rubber band it !
Your confusing things quite a bit....big difference between battery and servo wires......I do have 2 battery’s RX, witch power the CB’s but also power the smoke pump and the electric retracts.....
Using your logic, perhaps you should also double all the servo power? So everything except perhaps telemetry’s........
AND I don’t actually disagree with you...but like I said before feel free to do what you wish, but that doesn’t mean I have to follow suit......maybe your friend should have used a different Servo Clip......But I for one don’t see any advantage....that’s all I said. Case closed!
