Originally Posted by
Hydro Junkie
Why are you concerned enough to ask these, albeit legit, questions? You don't have an ax to grind, considering you are a MAAC member and the AMA and FCC don't affect you
Hydro, with all due respect I think he has just as much a right to participate in this forum as you do. He has stated several times that he occasionally flies as a guest at AMA sanctioned club fields. There is also an active agreement between the MAAC and AMA that is in play here. Personally I view this as discrimination based on nationality, something I feel you are above.
