Gluing in tank mount
I made a high tech glue injector to get the epoxy under the CF tank mount. Syringe, silicon fuel tube, and 1/8" air line
Filled with Six10 epoxy
Epoxy injected under the front and aft ends of the CF tank mount till it flooded out.
Front side cleaned up
Aft end cleaned up. I ran the Velcro strap through the center section several times to make sure there was no epoxy in the center strap channel.
