Finishing the CF pushrods
Stab control horns cut to size and sanded smooth
3mm ball joints bolted to the horns and clamp brackets assembled
Stab horns mounted and clamped in and stabs taped to fuse farings to hold them level for marking the pushrod length
Pushrods marked at end of aluminum caps and then 27mm added to the length for insert into the pushrod ends
CF rods cut, scuffed, cleaned, and epoxied in the aluminum rod ends as described in above post. My granddaughter asked for some extra epoxy for her project so I mixed extra and gave her the remaining. I did not see the results yet but I'm sure I will!
