I'll do a separate build log, but the tank I want to test will be a torro King Tiger metal lower with torsion bar suspension, metal roadwheels, sprockets & idlers and closed pin tracks, The upper hull and turret are Porsche, from the old all plastic Taigen King Tiger, it will have an IBU2 Pro with TPA amp and twin speakers, the turret is already IR so it has the recoiling barrel and high intensity flash but I might try out the new HL recoil with barrel smoke, and I'll be using a genuine tamiya apple and base. Like I said, the best of several different companies. Still not sure what radio I'll use, but the choices are Turnigy 9X, Flysky i6 or Flysky i10, or maybe just the cheapest HK 6 channel. One of the long term tests will be to see if the smoke messes up the flash over time.
