Cross pinning stab pushrods
Pushrod ends drilled
Pin from small pop rivit used to cross pin the pushrod cap to the CF tube. I found that each end was filled with solid epoxy as planned so I think they should not split on the inside.
Aluminum pins cut off
Cut off end hammered and peened flat to hold the pin in
After peening thin CA glue was applied to both ends
After the thin CA a drop of medium CA was applied to each end to make a smooth rounded bump and lock the pins in.
