If you can’t find an SDC 80 carb, a Walbro WJ 71 will work just fine. The WJ 71 is commonly used on most 85 to 120 size engines these days. Readily available from many vendors. The WJ 71 is a better carb than the SDC 80 ever was. Follow CK1’s advice on the stack and the vent line.
