Originally Posted by
icepilot
We had 2 sets that were sent here with the short pipes - that is wrong, and I believe you would melt or burn the tail cone with that setup.
I asked for (and got) 2 new, longer pipes that end only very close to the end of the cone.
Does anyone know the correct length for the tailpipe. I just purchased a new pipe from Skymaster for my K210 and it does not look long enough.
I have the turbine mounted all the way back to the former and it is as far back as it will go on the engine mounts. With a 25 mm distance from turbine to pipe the rear of pipe ends about 4” inches from the tear of the tailcone on the jet.
I know this can’t be correct. If anyone knows the actual length of the pipe (without the bell mouth) I would appreciate the help. The f16 is a G2 version.
Thanks, Gary
