RCU Forums - View Single Post - Yoshioka Flash
Thread: Yoshioka Flash
Old 08-30-2020 | 08:14 AM
H5606
Originally Posted by Jean Michel
Bonjour
Tu dois tout changer, chemise, piston, roulements, membrane de régulateur,, cla&pet de régulateur et joint de toutes sortes.
Tu chauffe le carter avec un décapeur thermique pour extraire les roulements.
Tu trouveras tout ce qu'il te faut chez RC JAPAN YS45.
A l'époque, j'utilisais une 11.9 apc avec le tuned pipe d'origine.
Salut.
Bonjour Jean,
Merci beaucoup pour votre aide.
If the engine runs for a couple minutes like it is supposed to, was hoping simply running or cleaning would make it healthy without parts replacement.
Also hoping it wouldn't be necessary and am willing to change all these parts however, I don't have a new plunger valve for the regulator diaphragm (not sure if this is a perishable part).
I've changed the bearings before using an oven so I don't anticipate difficulty doing it again.
I got my parts through YS Parts and Service in NV a couple years ago.
Never tried an 11x9; I think I tried an APC 11x8 but it didn't run as well as the 11x7 - I didn't play with pipe length though...
Salut.
