RCU Forums - View Single Post - Sig Four Star .40 Build Thread!!!!!!!!
Old 09-04-2020 | 07:17 PM
  #86
WMB
Originally Posted by tlmunn
I know this is an old thread however i am starting a 4 star 40 soon .Do you guys feel the sheeting of the leading edge to the wing spar a good mod .I am planning on beefing up the lading gear block and the wing hold down blocks and decking in the turtle deck.
Also how important are individual ail servos compared to only one in the center of the wing.First build in almost 40 years
The 4 star was my 2nd plane, 2nd build. Built it as designed. 40 Saito, 46TT, 51 Super Tiger, OS55, Saito 65, Saito 82. Saito 65 was the best match, 51 ST close 2nd. Put taller gear on for more prop clearance with the bigger engines. Plane will flat spin with CG moved back from stock. Gallons and gallons of fuel run through it, rough landings, just plain beat on. What a fun plane.
