Propeller advice
I tried float flying for the first time this year with my 1/3 Scale Super Cub and Scale Edo floats. Really enjoyed it but ran in to a problem.
I normally fly the plane with a wooden 24x8 Zinger prop, and I used this same prop off the water. The problem is that the spray impacts the tips and after a couple of flights the leading edge of the prop is shattered from hitting the spray.
How do the more experienced water flyers get around this problelm?
Is there a better prop?
Is there a way to protect the prop?
I tried holding more up elevator until the plane was on step, this helped but did not eliminate the problem.
Advice would be appreciated.
Flatflap
