Go Back  RCU Forums > RC Airplanes > Seaplanes
 Propeller advice >
Propeller advice
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Propeller advice
Old 11-09-2003 | 07:14 AM
Default Propeller advice
I tried float flying for the first time this year with my 1/3 Scale Super Cub and Scale Edo floats. Really enjoyed it but ran in to a problem.
I normally fly the plane with a wooden 24x8 Zinger prop, and I used this same prop off the water. The problem is that the spray impacts the tips and after a couple of flights the leading edge of the prop is shattered from hitting the spray.
How do the more experienced water flyers get around this problelm?
Is there a better prop?
Is there a way to protect the prop?
I tried holding more up elevator until the plane was on step, this helped but did not eliminate the problem.
Advice would be appreciated.
Flatflap
Old 11-09-2003 | 08:59 AM
Default RE: Propeller advice
I would try a composite prop. APC? Or maybe a carbon fiber but kind of pricey.
Brian
Old 11-09-2003 | 12:07 PM
On the positive side, you rarely ever break a prop when flying from floats and if you do you usually have a lot more to worry about than the prop. Invest in a equivalent composite prop; there is no other solution.
Peter
Old 11-09-2003 | 04:52 PM
JimCasey's Avatar
Anything but wood.
Master Airscrew props last for YEARS if you only fly from Water.
