Agreed. 2.4ghz doesn't need the padding that the old 72mhz receivers did. Self-adhesive velcro is quick and effective.
For best reception, do follow the advice above and put the two antennas at 90 degrees to each other. I put one vertical and the other across if possible. Also don't run them right next to anything metal as that can create interference and reduce range.
