Receiver Mounting >
Receiver Mounting
Receiver Mounting
Old 09-14-2020 | 07:36 AM
Default Receiver Mounting
I’ve recently started flying after many years with RC cars. With cars and my AM radios(yes it’s been a while since I had a car) I always just mounted the receiver to the chassis with double sided tape or inside a plastic receiver box. I started with electric foam planes and they all use Velcro to attach to the air frame. Now I’ve gotten into nitro and need some advice on mounting. I’ve heard you should wrap the receiver in foam to protect it from vibration (and crashes). I’ve also read that 2.4 receivers get warm compared to the old am/fm receivers and need air. So how do you mount your receiver? These will be new receivers in slow flying trainers for now. I also want to make sure I have the best possible location for the antennas so I don’t have to worry about aignal loss.
Old 09-14-2020 | 03:36 PM
speedracerntrixie's Avatar
My Feedback: (29)
I've been flying 2.4 since 2007. Always mounted receivers eith Velcro and if dual antenna run one vertical and one horizontal. If single antenna run horizontal. In thousands of flights I've had one incident that couldn't be explained.
Old 09-17-2020 | 12:13 PM
Moderator
Agreed. 2.4ghz doesn't need the padding that the old 72mhz receivers did. Self-adhesive velcro is quick and effective.
For best reception, do follow the advice above and put the two antennas at 90 degrees to each other. I put one vertical and the other across if possible. Also don't run them right next to anything metal as that can create interference and reduce range.
