Originally Posted by
methman2003ng
Thank you very much for your response. Unfortunately, I didn't save the pw, temp, and rpm when the engine was new. I noticed this problem after a crash landing. I run the turbine on kerosene and the rpm at idle and full throttle are 45k to 46k and 145k to 146k respectively. Additionally, I have not noticed any algae in the tank or fuel line. Finally, I have checked the filter and it appears clean. Thanks again.
Ayo.
‘If you crash this engine...then you should send it in for a check up....something is obviously wrong, and nothing you can actually fix....
‘’The setting don’t change during a crash Landing, but physical parts do
