iX20 programming
I need some help. I am over my head on this one. I have a jet that has aelerons and elevons. I am using my iX20 with a Mercury SRS in the plane.
I want to use flaps with the elevons. For wing type under Aircraft Type I am using Flaperon. With the Tail I selected Taileron-B Dual Rudders.
It does have two rudders. Everything works great with flaps up. Rudders are perfect in all modes.
When I put flaps at half or at Takeoff setting I get huge disparity in the right Elevon. It moves up 80%.
When I select Full flaps or landing flaps the elevons split almost 90% in opposite directions.
Flight mode is with the flap switch.
I can not trim the Elevons out individually.
What am I doing wrong? In the iX20 in the Monitor it shows this movement of Elevons gone crazy.
I've tried different wing types with different tail types to no avail.
I really need the flaps for takeoff and landing this jet.
Thank you,
Hal
