Originally Posted by
DavidAgar
Seven servo's with one of them being a retract servo may be a bit much for your battery. I am also concerned about the 7.4 voltage. Most of the common servos are only rated for 6 volts max, hence the packs that came in the plane. Is the retract servo a true retract servo? If it is not, that could be a power drain. Retract servos shut off upon completion of a cycle and a standard servo continues to drain power, especially if the retracts are not set up correctly. Good luck...
Correction my receiver battery is 6.0 volts. I will also be adding a SwitchGlo glow driver. Per their website it consumes 4.4 mAh per 10 seconds and takes power from the receiver battery.
Starting to think that the 2000 mAh maybe on the small side?
Your thoughts.
