Originally Posted by
cbk07
Joe1199, beautiful install and nice color swap! In the marked picture below, can you please tell me what size fuel tubing is being used from tank to UAT (see arrow) and also where you get the angled grommet/strain relief marked. Thanks and good luck with it!
i am always on the look out for parts to make neater installs! These are actually bicycle frame grommets and fit the Powerbox wire perfectly,
If you search ‘Shimano Di2 grommet’ you should find them
the fuel tube is 6mm Festo, I am using the CMjets tank and this is the same as the outlet
Hope this helps 👍
