Originally Posted by
Joe1199
i am always on the look out for parts to make neater installs! These are actually bicycle frame grommets and fit the Powerbox wire perfectly,
If you search ‘Shimano Di2 grommet’ you should find them
the fuel tube is 6mm Festo, I am using the CMjets tank and this is the same as the outlet
Hope this helps 👍
Definitely helps! Great find on the grommets. Thank you
